toshiba 48pj6db HELP
Discussion in 'General TV Discussions Forum' started by dazzaruss, Jan 20, 2008.
  1. dazzaruss
    dazzaruss
    my toshiba 48pj6db rear projection tv wont turn back on the red led is coming on i can hear the relay clicking and the tubes have what i believe is ht crackle but are not glowing im suspecting the convergence board as i know this to be a common fault on toshiba's any one else had this problem or know where i can source a new board
  2. dazzaruss
    dazzaruss
    decided to try unplugging all the power cables from the power supply and try plugging them in one at a time till the relay clicked over it was ok till the yellow and white cable was plugged in to the power board so now suspect imgetting too much power drawn by that board. so maybe faulty diode, capacitor,transistor or one of the transistors has gone found a local toshiba approved repair shop to me who is prepaired to come and trace the fault for me for £50 so may take that route at end of month
