Toshiba 46WM48P is there a service menu?
Discussion in 'Televisions' started by DpM, Mar 21, 2005.
  1. DpM
    DpM
    Jul 15, 2003
    4,259
    High Wycombe, UK
    +795
    The title says it all. The problem is that through the component input on this set the DVD pic is to low. When the DVD has no disc in the splash screen/wallpaper is about 1.5cm too low as I have a black border across the top. This isn’t a problem with region 1 DVD's but when watching a region 2 disc that area of the screen has a pic but I flickers all the time. But in the standard menu I can only move the pic left or right. Is there a service menu where I can make this adjustment? I there is then I would be over the moon with this set as it is over all superb, if not im I guess ill have to get it swapped for another.
    Dean
