Toshiba 46wm48(p) Vrs 46wm48(b)
Discussion in 'General TV Discussions Forum' started by godzuki, Mar 9, 2005.
  1. godzuki
    godzuki
    Hello there.
    As someone keen to buy the toshiba range of DLPs (think they look fab), I was wondering if anyone could tell me the difference between the 46WM48P and the 46WM48B.
    From the following site (http://www.pricerunner.co.uk/search?q=toshiba+wm48 ), it appears that the *P version is 50hz and the *B version is 100hz. However, perhaps I have misunderstood the DLP technology, but I thought frequency refresh rate did not apply to DLP TVs?
    If anyone could tell me the difference between the listed models, I'd be very grateful. I just wanna make sure I buy the best one....
    Thanks in advance
    John
  2. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
  3. kourosh
    kourosh
    Feb 6, 2005
    14,554
    Portsmouth
    +1,038
    i phoned tosh my self before i ordered mine and they told me with dlp you cant do 100hz they are all 50hz :thumbsup:
