TOSHIBA 46wm48 - How Do You Tune the Sky Remote Control to Recognise TV?
Discussion in 'General TV Discussions Forum' started by godzuki, Mar 14, 2005.
  1. godzuki
    godzuki
    Hey there.
    Any advice on how to Tune the Sky Remote Control into specific TVs would be very much appreciated.
    Cheers.
    Jon
  2. dbisping
    dbisping
    Dec 14, 2004
    42
    to reprogram the Sky remote
    Press TV on the Sky Remote Control
    Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
    Enter three digit code from list for the receiver (early remotes flash twice), you may have to try several to you find the right one
    Press select to enter code structure (the LED will flash twice if a valid code has been entered).
    Now press the STDBY button and test other functions.
    Not sure which one works for the Tosh but it likely to be one of the following (It works perfectly for my SKY+ remote control my 46wm48)
    536 063 271 098 117 232 530 581 130 473 088 182 064
    Krgds
    Dave...
  3. electrosim2001
    electrosim2001
    Nov 22, 2004
    101
    Used your info for my Panasonic Sky set top box. 536 worked, and my remote now controls my Tosh 46".
    Thanks for the instructions. Thomas.
