weyland-yutani
Established Member
any reason i should turn my nose up at this bagain? any major downpoints i've missed since checking it out a few months ago, when it was £1600.
Apart from HTPC running Dscaler![]()
maidstoneman30s said:The Pauly,
I do not know why you have such a bad distaste for the Toshiba. I had several demos, prior to buying the Toshiba 46WM48P.
I see you mentioning various '' faults'' on the screen, but not a good word to say about it.
I have been amongst many thread posters, who have mentioned how awesome and clean the image can be, even sharper than some Sammy's. Theres one member on here who can verify the move from Tosh to Sammy and a minimal loss in sharpness.
Overall I have , crappy feeds and decent feeds. I dont not suffer from horizontal blur on an everyday scale.
Nor do I suffer from artifacts every day or week. It really depends on the feed and bitrate.
I can honestlyu say, that the Tosh has impressed me with its picture quality and overall performance.
I have a problem issue with HDMI blank spots, but thats another issue.
Elephant man can vouch for what a good set it is.
Not every DLP is without its flaws. If they were perfect, we wouldnt put our two pennies here at AV Forums, but instead sit on front of it with glee.
Maidstoneman30s
Congratulations. You're very lucky. You will be the envy of every other Toshiba owner on the planet, as you seem to have the only set that doesn't suffer from these picture issues.mrmoo said:I DON'T suffer from any weird oil paintings or blurs...
It's very simple - the picture quality is not a patch on the Samsung and Sagem models I auditioned alongside the Toshibas. Why should I have enthusiasm for a set that performs under-par compared to the competition?maidstoneman30s said:The Pauly,
"...a minimal loss in sharpness..." means it is less sharp. I rest my case.maidstoneman30s said:I have been amongst many thread posters, who have mentioned how awesome and clean the image can be, even sharper than some Sammy's. Theres one member on here who can verify the move from Tosh to Sammy and a minimal loss in sharpness.
On my Samsung I don't suffer from horizontal blur no matter the quality of the feed - ever. Nor does the set add any "interesting" artefacts - ever.maidstoneman30s said:Overall I have , crappy feeds and decent feeds. I don't not suffer from horizontal blur on an everyday scale.
Wanna bet?maidstoneman30s said:Not every DLP is without its flaws...
Nowhere do I state that mine is the only choice. Read the other threads I have posted on. In almost all of them I stress the need to audition any set before buying, as what may be acceptable for one person may not be acceptable for another. Nowhere have I stated anything as patently ridiculous as you are suggesting. This is not the only choice, but after a couple of months and numerous demos and comparisons it was the correct choice for me.maidstoneman30s said:I think you have convinced yourself that your own choice is the only choice.
Well done.
I've convinced myself of nothing. The only thing that convinced me of anything was the superb showing of the Samsung models in demos, where they handled everything I could throw at them, with no problems whatsoever.the_pauley said:Perhaps you can give me a good reason why I should have chosen the Toshiba with its picture flaws over a set with no such faults?
the_pauley said:Congratulations. You're very lucky. You will be the envy of every other Toshiba owner on the planet, as you seem to have the only set that doesn't suffer from these picture issues.
the_pauley said:Firstly we have mrmoo who claims that his Toshiba displays none of the faults of every other Toshiba DLP in the world, picture issues that are not only well documented in these forums, but in practically every professional review of the sets.
mrmoo said:I dont appreciate your derision, it is uncalled for and the main reason I rarely comment in this forum. I have referred your comments to the moderators.![]()
Refered my comments to the moderators???mrmoo said:I dont appreciate your derision, it is uncalled for and the main reason I rarely comment in this forum. I have referred your comments to the moderators.
And in case you hadn't noticed there are several million standard definition DVD players and several billion discs sitting on the shelves of people the world over and they'll be there for quite a while. Would it be unreasonable to expect a £1,000+ piece of equipment to play these without attendant blurring and other extraneous artefacts?dalespitfire said:In case you hadn't spotted these are HD ready displays, and to my knowledge a PC is currently the only way to view such material.
OK - but what about the majority of ordinary everyday users that don't want to attach a grand's worth of HTPC or an £800 descaler in order to achieve the quality of picture that comes as standard, straight out of the box with the Samsung? You know, the people who just want to turn on their £1,000+ purchase and plug in their DVD or Sky Box and expect it to deliver a problem free picture?mrmoo said:I always use an HTPC and long ago discovered what was causing horizontal panning blurs on my set. Its all there back in the history.
Nothing wrong with his comment.mrmoo said:I have referred your comments to the moderators.![]()
the_pauley said:And in case you hadn't noticed there are several million standard definition DVD players and several billion discs sitting on the shelves of people the world over and they'll be there for quite a while. Would it be unreasonable to expect a £1,000+ piece of equipment to play these without attendant blurring and other extraneous artefacts.?
the_pauley said:what about the majority of ordinary everyday users that don't want to attach a grand's worth of HTPC or an £800 descaler in order to achieve the quality of picture that comes as standard, straight out of the box with the Samsung? You know, the people who just want to turn on their £1,000+ purchase and plug in their DVD or Sky Box and expect it to deliver a problem free picture??
There are only two models of this TV available, the 46" and the 52". I demoed both, twice each. I went for the second demo on each as I wanted to be sure that the problem wasn't just with the first two models I tested. I must admit I was doubtful that this was the case, having seen the 46" and the 52" exhibit the same problems. But I did give them a second go anyway on two different sets. Exactly the same result.Stuart Wright said:Pauley, you can't really start saying that all models of the Tosh can be as bad unless you've either seen several yourself or hear reliable stories from elsewhere which confirm your experiences.
Every time you drone on about this you make my point for me. With the Samsung I don't need anything extra, such as a computer attached to the TV -be it £350 or £1,000- to do "...the job without issue..." The TV does it all on its own. Strange but true...Erm, a grand for an HTPC!!! I paid £350 for a PC that does the job without issue.
Er... nothing. The clue is in the phrase "...standard definition..." and the point is perfectly clear.dalespitfire said:Point being? What has this to do with high def material?
No mate, that's a "Check it out it carefully for yourself."weyland-yutani said:so that's a no then?
the_pauley said:Every time you drone on about this you make my point for me.
the_pauley said:With the Samsung I don't need anything extra, such as a computer attached to the TV -be it £350 or £1,000- to do "...the job without issue..." The TV does it all on its own. Strange but true...
Really? Are you quite sure of that? Only it seems to contradict a statement you made earlier on in the thread. When I made the statement...the_pauley said:With the Samsung I don't need anything extra, such as a computer attached to the TV -be it £350 or £1,000- to do "...the job without issue..." The TV does it all on its own. Strange but true...dalespitfire said:I didn't NEED too either...
...your reply was...the_pauley said:In addition to the "motion blurring" issues, that effect that has been refered to as the "oil slick" effect was particularly noticeable on skin tones. No amount of picture tweaking or switching of leads rectified these problems.
Care to comment?dalespitfire said:Apart from HTPC running Dscaler![]()
I'm not sure what you find "obnoxious" in that statement - the use of the term "drone on" or the fact that you keep making my point for me. Either way I'd say you're being a tad hypersensitive.the_pauley said:Every time you drone on about this you make my point for me.dalespitfire said:You really are quite obnoxious aren't you! Interesting you can take that tone and the Mods let it ride yet I've no doubt this comment will be pulled.
EDIT: I should know better.the_pauley said:Anyway, I'm slightly thicker-skinned than some on this thread and I'd be quite happy for the remark to stay, if only to show how for the second time in this debate (the first comment was removed) the opposing side has resorted to personal abuse. It's also the second time someone in the opposing camp has stated or implied that the mods should somehow take issue with my comments.
I'm commenting on a TV set, whereas the opposing side in this debate is resorting to personal abuse and urging that I should be censured for my comments.
