Toshiba 46WH08 + Dolby Digital?
Discussion in 'General TV Discussions Forum' started by gpegler, Jan 18, 2001.
  1. gpegler
    gpegler
    I have recently bought the excellent 46WH08 TV. I have a cranky old Samsung 807 DVD connected to it via a scart lead to the RGB socket and a digital coaxial cable for sound.
    My question is how can I tell if I am getting Dolby Digital sound while a DVD is playing? There is something in the TV manual about one of the on screen menu headings displaying information if Dolby Digital is working, but I can't get that to work.
    Any help would be appreciated.
    Thanks.
    Gary Pegler
  2. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    Ensure your DVD is set to replay Dolby Digital. Check the menu on the disc, you may need to select DD, possibly from within the languages menu.
  3. nickoff
    nickoff
    gpegler.
    Can you tell me what the screen dimensions are for the 46 Tosh. I know its 46 inch diagonally, but what is the screen size in height and width? ta
  4. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    948
    Scotland
    +18
  5. Guest
    The DVD movie has to have dolby support!
    Press the dolby button at the bottom of the remote (it is like a bd sign)
    This will bring up the dolby menu.
    This is what I did.
    1)use the surround sound test, this goes through each speaker and produces a fuzzy sound.
    2) If you recived a sound from each speaker go to the first screen again and select the top option (dolby I think) then press enter and exit.
    Listen closle to one of the rear speakers to see if it works
