Toshiba 46" Rear Projection TV
Discussion in 'General TV Discussions Forum' started by dazap, Feb 19, 2005.
  1. dazap
    dazap
    Oct 21, 2004
    1,026
    shrewsbury
    +131
    Just turned it on this morning and have 3 pictures all like ghosts behind each other.
    Have had a look at convergence in the general menu but instead of the usual colours I have pink & green & all shifted to the right.
    Any ideas what's going on with it?
  2. Razor
    Razor
    Dec 15, 2004
    37,727
    2
    +12,503
    Has it been moved or knocked?
  3. dazap
    dazap
    Oct 21, 2004
    1,026
    shrewsbury
    +131
    No went to bed last night & it was fine, then doing this as soon as turned on this morning
  4. Razor
    Razor
    Dec 15, 2004
    37,727
    2
    +12,503
    Oh dear. Doesn't sound good.
  5. TonyA
    TonyA
    Oct 16, 2004
    2,765
    London
    +217
    Unplug the set completely from the mains and leave for half an hour.
    Re-plug it in, and check again.
    A "cold" reset may kick it back to normal.
    <Fingers-Crossed!>
  6. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,294
    oxfordshire
    +408
    You havent moved any unsheilded speakers near the tv?
  7. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,672
    I assume from the description of the problem that this is not a DLP machine,but a CRT based RPTV.
    You've presumably done a user level convergence,from what you've said....did the convergence actually fail to do anything to correct the problem?....if so,then you do have a major problem,and if the set is in warranty,I would strongly advise you to call someone out to fix it.
    There are links here to doing service level convergence on Toshiba CRT based RPTV's,but none of that is for the faint hearted,or those with a warranty,as entering the menu will invalidate your warranty,and potentially erase a lot of the default settings if not done carefully.
  8. dazap
    dazap
    Oct 21, 2004
    1,026
    shrewsbury
    +131
    Thanks to u all for the advise i have had the set for 4 years now and luckly i still have 12 months extended warenty on it feeeeeeewwwww as the set is now no longer availble do u think they will still do the parts to fix it.
    Thanx
  9. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,672
    The warranty may include the eventuality of not being able to fix it,but at that age,there should be parts readily available...good luck.
  10. dazap
    dazap
    Oct 21, 2004
    1,026
    shrewsbury
    +131
    service man coming tomorow thanks again evrey 1
  11. dazap
    dazap
    Oct 21, 2004
    1,026
    shrewsbury
    +131
    well he came went into service mode and couldnt do anything and said hmm i dont no i will have to ring toshiba on monday really woried now i really think im gona be without my tv
  12. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,672
    They are pretty complex pieces of gear when you take into account focus,convergence and all of the electrical aspects as well....if you are without it for a while,at least it should be fixed and you should know more by Monday...good luck.
