toshiba 46 DLP/Denon 2910 HDMI problem
Discussion in 'General TV Discussions Forum' started by charles, Jun 13, 2005.
  1. charles
    charles
    Jul 6, 2001
    1,354
    63
    norwich
    +174
    I am using the above DVD player via HDMi to the Toshiba.Using 720 and component in the set up.The picture cuts out every few minutes. Sound continues. Any ideas?
    Charles
  2. P&J
    P&J
    Mar 11, 2005
    24
    3
    The 2910 manual states that when playing a PAL disc via HDMI the setting should be NTSC (not PAL and not Auto). This solved my similar problem, despite sounding daft.
    Have fun.
  3. Les
    Les
    Jan 1, 2005
    103
    Livingston, Scotland
    I have identical problems with my Toshiba 52WM48 and a Panasonic S97 DVD player. Most annoying. Using them via component is problem free, and excellent pictures.
  4. jianf
    jianf
    I had exactly the same problem with my Toshiba 46 and my Panasonic s97 player. After a full day of tests and changing parameters I found out that it only happened when sending the HDMI video output to the TV and not the audio, if I send both, video and audio, all is fine (as I use my Hi-Fi for audio I thought it made no sense to send the HDMI output to the TV!).
    I don't know about the Denon player, but with a bit of luck it will be the same problem :)
