N
Nomal
[-]Hello
Could anyone with a 42XV553DB or similar XV series LCD TV if their set has a continuous high-pitched squeal coming from the back of the unit on standby only, or is mine just knackered?
I brought it about 4 months ago and it's been doing this ever since new. I believe it could be the feed-back transformer but could also be anything else. I can only describe the noise as a continuous quiet high pitched wine that can only be heard when the room is silent, however, when you're trying to sleep in the room with it you can here it and does drive you a bit nuts after a few months LOL. As soon as you ask the TV to turn on it stops before the panel has lit up or sound kicks in, same goes when turnin off, the noise isn't present until the panel has fully turned off and TV "clicks" into total off mode (I.E. standby)
I can't be bothered to get it replaced/repaired if it's just a Toshiba thing. Any thoughts would be appreciated. Also, what is the green L.E.D. next to the red standby L.E.D. for? It randomly comes on with the red standby light for short intervals and then goes off again. When it's on the TV "clicks" as if it's doing something, when it goes off, five minutes after it's come on the TV clicks again. While the green L.E.D. is on, I think the high-pitched squeal stops. As if it's not in standby during this period.
