Toshiba 42WP46P, Sky & DVD
Discussion in 'Plasma TVs' started by actionorton, Dec 5, 2004.
  1. actionorton
    actionorton
    Hi people
    Just conned into buying a Toshiba 42WP46P.
    My question is that i have an rgb scarts going from my sky+ cheap DVD player to my plasma, and the picture quality on both is rather poor.
    If get one of these scart to vga converters, will i notice an improvment.
    The picture looks very distorted when the screen has to do a lot of work.
    Is this just the Toshiba 42WP46P plasma?
    Any info will be greatly appreciated.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    tosh are panny clones IIRC and its probably a PW7 clone so scart board does look pants..... depending on what else you have RGB>VGA box or a component card would be bettter have a search may want to upgrade your DVD player too
  3. actionorton
    actionorton
    Thanks hornydragon.
    Still a bit reluctant to part with 125 quid for a scart to vga quid if the diffrence ia only just noticeble.
    Will i get a true reflection of the quality if i connect my laptop up to the plasma and play a DVD, or am i barking up the wrong tree?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    more than just noticaable.....................
    get a copy of DVE for £13 makes the biggest difference but the RGB converter will squeeze every inch out of the screen..... go see one in action plenty of people have them take your scart board and do a PAP test or see p[osts by Terressa TT
