Toshiba 42WH36 Stand ?
Discussion in 'General TV Discussions Forum' started by toadie, Nov 2, 2003.
  1. toadie
    toadie
    Dec 14, 2002
    330
    16
    Hi there, Anyone know where I can buy the stand for the 42WH36, I've had a look around on the net and it seems you can only buy it with the tv, and not on its own.
    Thanks in advance
    Toadie
  2. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    Have you tried Toshiba?
  3. posser
    posser
    I was also after a stand for the Toshiba 42WH36.
    Toshiba put me in touch with their Spares Distributor SEME Ltd,
    who can be contacted on 01280 826004.
    They should be able to help.
    Regards,
    Posser.
  4. toadie
    toadie
    Dec 14, 2002
    330
    16
    Thanks Posser ! Appreciated !
    cheers
    Toadie
  5. toadie
    toadie
    Dec 14, 2002
    330
    16
    Posser,
    I contacted SEME, and they said they can do the stand inc delivery for £100.
    Although, it was obviously cheaper to buy the stand with the Tv, but I wasn't sure if I wanted it.
    Mart...
  6. rajp
    rajp
    Can anyone with the stand for the 42Wh36 let me know the height within the stand? i.e I want to know if my centre channel will fit in it?
  7. valmiki
    valmiki
    Nov 14, 2003
    60
    Swansea
    rajp, if you get an answer to your question, could you inform us of it as well please mate?
    the blurb from toshiba (on their website) doesn't provide all the info that you would need unfortunately...
  8. acucobol
    acucobol
    Sep 7, 2003
    62
    Just over 7 and a half inches, is the internal gap.
    I have my front centre and scart switch box located there.
  9. Alan_W
    Alan_W
    Sep 20, 2000
    1,393
    S Wales
    +188
    Thanks ............but is that height or width? :confused:
    Will a Mission 77 centre speaker squeeze in? :rolleyes:
  10. acucobol
    acucobol
    Sep 7, 2003
    62
    that was height.
    it is 33 inches wide internally.
  11. Alan_W
    Alan_W
    Sep 20, 2000
    1,393
    S Wales
    +188
    Thank you
    :clap: it fits it fits :clap:
    Now to "tell" thw wife we are having one :smoke:
