Toshiba 42wh18b v 50wh18b
Discussion in 'General TV Discussions Forum' started by the_moose, Apr 28, 2002.
  1. the_moose
    the_moose
    Apart from the size is there any other significant differences like picture quality? Thanx
  2. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    What about the new 42PW23P? Looks like the others but without 100Hz and DD5.1 and a bit cheaper. Check it out here www.robertsons-online.co.uk.
  3. the_moose
    the_moose
    Thanx I will check it out, but please don't confuse me, a choice of two is hard enough!
  4. Guest
    Seems as though both Tv's are the same,same amount of scarts and both have component and built in DD with 100hz.
