Toshiba 42PW33 service menu
Discussion in 'General TV Discussions Forum' started by xtermin8, May 23, 2005.
  1. xtermin8
    xtermin8
    Having just bought a Toshiba 42PW33 RPTV Tv and being expremely happy with it, I was wondering if anyone knows how to get into the Service Menu. I want to know so I can check the convergence is correct and set the picture up as best as possible.
    Hope you can help.
    Cheers,
    Rich
  2. chaz 2112
    chaz 2112
    Apr 17, 2005
    523
    Frome
    +74
    press mute on remote,then press mute on remote and almost instantainiously(?)press menu on the tv panel on left hand side.
  3. cosmin_v
    cosmin_v
    May 7, 2005
    10
    Bucharest
    hi xtermin8,
    did you manage to save the convergence settings in the service menu? I have this problem and I was told that there is a bug of the processor who fails to save the convergence settings?!
  4. chaz 2112
    chaz 2112
    Apr 17, 2005
    523
    Frome
    +74
    i had no problems with convergence.had a blue and yellow patch appear on screen after a couple of days.had this with 3 sets.
