toshiba 42pw33 service menu problem
Discussion in 'General TV Discussions Forum' started by cosmin_v, May 7, 2005.
  1. cosmin_v
    cosmin_v
    May 7, 2005
    10
    Bucharest
    Hi@all,
    go easy on me, it's my first post here :D
    So, I've just bought a 42" Toshiba CRT RP and, obviously it needed badly a convergence adjustment at the service menu level. Problem is that the convergence settings don't get saved, or get reseted the next time I switch on the TV.
    I've called in the Toshiba, but they bumped into the same problem.
    Is that another way to save the settings beside switching off the TV (not putting it in stand by via the RC, but powering it down)?
    Funny thing - the other settings I've changed in the service menu got saved... Only the convergence keeps switching back to default :mad:
    Any help would be apreciated!
    Cosmin
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    If Tosh UK can't help then you might be stuck, but there is a fall back position. Ask about getting the set ISF'd. This is a full on top to toe set up of everything to get the max performance from your TV. If anyone outside Tosh UK will know if the set can store its convergence settings then an ISF engineer is your best bet.
    Gordon Fraser at Convergent AV should be your first port of call http://www.convergent-av.co.uk/
    Regards
    Chris
  3. cosmin_v
    cosmin_v
    May 7, 2005
    10
    Bucharest
    Thanks Chris,
    I've forgot to mention that I'm from Bucharest-Romania, so Gordon Fraser might ask for a house call twice the amount I've paid for the TV :rotfl:
    A friend of mine followed my lead and bought the same tv; he has the same problem, which makes me think that it's a software bug.
    Cosmin
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    :D I think you're right about Gordon.
    I would pursue the problem with the manufacturer. If it's a bug in the software then they should be working on a fix for it.
  5. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
    Moved from CRT Projectors forum
  6. cosmin_v
    cosmin_v
    May 7, 2005
    10
    Bucharest
    @all: help needed! Anyone has an ideea?
