Toshiba 42PW33 LCD TV
Discussion in 'LCD & LED LCD TVs' started by oni, Jul 18, 2004.
  1. oni
    oni
    I am looking to order the following TV: Toshiba 42PW33
    see picture
    Does anyone have this TV? Is it any good? For a LCD TV it seems pretty cheap, which makes me nervous?
    Also, what does widecreen signalling mean? It says on the website it is 16:9 Aspect Ratio, but on the description it mentions widscreen signalling?
    Finally, does it have progressive scan? Is that important?
  2. reckless
    reckless
    Dec 21, 2003
    983
    28
    +30
    It's an LCD rear projection set, not an LCD screen as such, hence why it's cheap. A 42" LCD screen will set you back about 4-5 grand. If you just meant it's cheap for an RPTV then apologies for misunderstanding the question.
    I assume widescreen signalling simply means it can recognise when it's receiving a widescreen image rather than a 4:3 image and use the correct screen mode to display it. Just like a normal WS telly will have modes such as Zoom, wide, smart (to fill the screen with a 4:3 image), 14:9 etc.
    Again, apologies if this is incorrect.
  3. oni
    oni
    :smashin:
