Toshiba 42PW33 Horizontal Grid Lines
Discussion in 'Televisions' started by Parv, Aug 17, 2005.
  1. Parv
    Parv
    Hello,
    Can anyone check there 42" RPTV and tell me how high the horizontal grid lines in wide are, by measuring the inside edges of one of the rectangles, how high in mm is it?
    Are all the rectangle cells in the horizontal the same distance apart from the bottom to the top of the screen?
    The problem is that I changed the horizontal line to make them even and level across the screen, but i have noticed that the hieght of the lines is important beacuse if they are differnt when text or images scroll up the screen they will change shape, became shorter or longer depending on the size of the cell above it.
    So can some please confirm that what the original hieght of the cells is using the inner measurment of the cell/horozinal lines. And wether the cells/lines are all equal hieght across the screen.
    Cheers.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,752
    Somewhere in South Yorkshire
    +4,906
    Not a DLP TV, so, moving to a more suitable forum.
