toshiba 42pw23p screen replacement
C
clown5091
hi
i have the toshiba 42pw23p and i have my centre speker on top but I was moving my room round and the centre speker fell off and damaged the front plastic sceen and now i have a big scratch in it and it show quite badly when watching what i would like to know is how much it would cost to get a replacement and it fited because it quite off puttin
any help would be good
thanks si
Shady Deal
If you ring Toshiba they will advise you of one of their service centres. (I know there is one in Swindon but can't remember their name)
A screen will cost you about £400 fitted and I would advise you get a good engineer to do the job. It is quite difficult to get the screen to the correct "tightness" all the way across, without any sagging!!
I have done it by putting loads of magazines on the floor and fitting the screen face down.
Give Toshiba a ring though and get someone else to do it, especially as you can have the mirror/crt's cleaned at the same time!
Regards
