Toshiba 42PW23P Focus
Discussion in 'General TV Discussions Forum' started by nathan_silly, Jan 31, 2003.
  1. nathan_silly
    nathan_silly
    I've got a Toshiba 42PW23P, using component from my 110V DVD player.
    The center & top convergence is more or less spot-on, but the bottom three grids are more blurred (the blue). Instead of a white cross, it's white cross with a blue border- as if the blue cross is bigger all-round.
    If I move the blue on the bottom three, it makes no difference. I have adjusted the blue focus pot, but this obviously adjusts the entire screen for blue.
    How can I adjust the lower portion of the screen?
    Also I've noticed it seems to loose the convergence settings (or at least slightly mis-convergence) Do I need to leave the TV on standby?
    Nathan
