Toshiba 42PW23 or Toshiba 42PW33 ?
Discussion in 'Televisions' started by Mr fuse, Jul 26, 2004.
  1. Mr fuse
    Mr fuse
    Okay now that ive been convinced to go for a rear projection screen Ive noticed for £50 more i could go for the 42pw33 rather than the 42pw23. should I go for this and whats the main differences?
  2. blackadder
    blackadder
    Jan 4, 2004
    1,490
    48
    Wigan/Lancashire
    +34
    There the same except for the external looks,in my opinion the 42pw33 looks better.
    Below is an email i received from toshiba regarding the differances with the 23 and 33 models.
    The only difference between the 42PW23 and the 42PW33 is the cosmetic change to the stand. All the other features and specification are the same.Both of these models have component video input
