Toshiba 40WH08B & 100Hz
Discussion in 'General TV Discussions Forum' started by johndon, Feb 12, 2002.
  1. johndon
    johndon
    Feb 3, 2002
    1,988
    63
    +122
    I have a Toshiba 40WH08B which I am very pleased with.
    If I switch to 100Hz the on-screen menus from both the tv and sky digital flicker (which they don't at 50hz) although the picture itself is rock solid.
    Is this normal or do I have a problem with the TV?
    John
  2. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    My 46who8b doesn't but have seen many that do!
    You can also see this effect on a lot of Toshiba 100hz CRT widescreens but as you say the picture is rock solid.
    I don't think it is anything to worry about and if the picture without the menus is great then just enjoy it.
    Regards
  3. Duncan Harvey
    Duncan Harvey
    I get menu flicker on 100 hz with menus on my 56 who8b - but again the pic is rock solid. Flicker was noticable when watching a video cd of stills so I now have the 10hz turned off. Couldnt notice any difference whatsoever with normal viewing so now keep mode off as a default setting.
  4. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    It is normal and the 100Hz setting is the best option for general viewing and 'Natural' for Menus/Text.
    Search the TV forum for a more detailed, technical explaination. I've seen one somewhere.
  5. johndon
    johndon
    Feb 3, 2002
    1,988
    63
    +122
    Thanks for the info, I'm a lot happier now.
    John
