Toshiba 40L2436D only showing SD not HDTV ?
Discussion in 'LCD & LED LCD TVs Forum' started by gbrowne, Jul 1, 2015.
Tags:
  1. gbrowne
    gbrowne
    Jul 1, 2015
    5
    Wareham, Dorset
    It seems I must be doing something really stupid cos I'm sure this should just work out of the box.
    Set up did auto tune via newish terrestrial aerial, found about 60 digital TV channels. The signal strength is shown as 98% and 100 quality. However, when I view these channels they look SD and the 'i' info screen confirms they are all SD.
    We use the mighty 200kW Rowridge Freeview transmitter on the IoW, which ukfree.tv lists the transmitter as carrying at least BBC1 and 2 etc in HDTV on channels 101 and 102 etc.
    What am I doing wrong ? Do I need to enable something in a hidden Service Menu or something ?
    Help !!!
    Cheers,
    Dimwit of Wareham.
  2. silversurfer24v
    silversurfer24v
    Jan 15, 2006
    756
    3
    28
    lincs
    +83
    If you switch to channel 101/102/3/4 etc for the HD channels do you get a picture
  3. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    Some website specifications can be a bit hazy at times. Several do not specify that this model had a DVB-T2 tuner which is essential for HD channel reception in the UK. However some dealers seem to think it has, so I hope you are lucky in this respect. Being specified as Full HD does not guarantee that a set has a UK HD DVB tuner. In other countries HD can be received on DVB-T, which causes confusion.
    Toshiba is sourced from many manufacturers, rather than being specific 'make'. This appears to be a discontinued model.
    You could plug in a HD set top box or PVR in order to receive HD channels. However if this was sold to you as something it isn't then you have good grounds for a refund.
  4. gbrowne
    gbrowne
    Jul 1, 2015
    5
    Wareham, Dorset
    Thanks Mike and Silversurfer,
    Channels 101 etc just show SD.
    I wonder if there is any way of finding out the tuner capability - hidden service menu maybe ?
    On the box it just says 'Full HD 1920 x 1080'. I got the TV secondhand, but unused.
    Wonder if the tuner is a plug in module inside....
    Cheers,
    Geoff.
  5. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,229
    Poole
    +11,861
    Does the label/box say "Freeview" or "FreeviewHD"?
    If it doesn't say "FreeviewHD" then it cannot receive HD broadcasts.
    The product description on Amazon says Freeview.
  6. gbrowne
    gbrowne
    Jul 1, 2015
    5
    Wareham, Dorset
    Thanks very much everyone, you had cracked it. The box only says Freeview not FreeviewHD. Quite misleading really as other labels say Full HD. I understood that to mean it would have a HD tuner. I'll have to look out for a tiny DVB-T2 set top box I guess. What a pain. More cables again !!
    Thanks again guys.
    GB.
  7. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,229
    Poole
    +11,861
    FullHD is the screen resolution so it could, for example, display HD from a Freesat HD or FreeivewHD receiver via HDMI.
  8. gbrowne
    gbrowne
    Jul 1, 2015
    5
    Wareham, Dorset
    Thanks TS, but isn't that what 'HD ready' is ? I understood 'Full HD' means this thing does HD by itself without external sources ?
    Don't suppose you've ever come across a tiny STB for DVB-T2 ?
    G.
  9. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,229
    Poole
    +11,861
    HD Ready means a 128ox720 display, Full HD means a 1920x1080 display.
  10. gbrowne
    gbrowne
    Jul 1, 2015
    5
    Wareham, Dorset
    Ah, got it now. Thanks for that. I consider myself reasonably tech-savvy, how on earth is the average non-techie Joe meant to work it all out :eek:))
    Thanks guys.
  11. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    As if life was not confusing enough I have 24" Panasonic upstairs which is HD Ready (720). However it has a DVB-T2 tuner and gives a very good picture on the HD channels. . It's quite 'old' in that it has an old style LCD screen. I believe Sony sold some of these as well When I researched the net for gbrown a number of sites were saying his tv has a DVB-T2 tuner which is so very wrong.
  12. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    @gbrowne
    thread moved to the LCD & LED LCD TVs forum
    Curly
