Toshiba 40L1333DB green and red flashing light & TV wont turn on ?
lemonismyname
Hi there this is my first post on this forum i hope it is in the right place.
Recently my 40" toshiba 40L1333DB tv will not turn on and the power led simply flashes red and green. I used to be able to fix the problem by powering it on and off at the wall but this no longer helps. Another forum suggested that toshiba tv's can be flashed from usb but i could not find a compatible file.
Any help with this would be much appreciated! Thanks all
