Toshiba 3d Help
Discussion in 'General TV Discussions Forum' started by Ryanslater1985, Jan 11, 2012.
  1. Ryanslater1985
    Ryanslater1985
    Jan 11, 2012
    5
    Hi Guys
    Recently purchased the Toshiba TL868 with accompanying 3d blu-ray DVD player, HDMI lead and Toshiba active shutter 3d glasses.
    I have purchased Lion King in 3d and that works fine (so I know the DVD player, glasses & HDMI lead are all compatible)!
    However, I have purchased Piraña in 3d and cannot get it to work. It is asking me to select 'side by side' or 'top to bottom' when selecting 3d mode. Neither work & it remains blurry & all mixed up.
    Any ideas why this may be?
    Cheers!
    Ryan :thumbsup:
  2. welsh mussels
    welsh mussels
    Sep 23, 2008
    1,325
    conwy
    +88
    both 2d and 3d versions are on same disc if i remember rightly ,
    you don't need to select side by side are top and bottom with this film just select play movie should ask if you want to watch in 2d or 3d,
  3. Ryanslater1985
    Ryanslater1985
    Jan 11, 2012
    5
    It asks every time to sect either side by side or top to bottom.
    Does it make a difference if the DVD isn't blu-ray?
  4. welsh mussels
    welsh mussels
    Sep 23, 2008
    1,325
    conwy
    +88
    yes , needs to be a 3d blu-ray
  5. Ryanslater1985
    Ryanslater1985
    Jan 11, 2012
    5
    How come? If the DVD is in 3d how are you supposed to play it??
  6. TONYELISE
    TONYELISE
    Jun 21, 2010
    2,680
    3rd Rock from the sun.
    +760
    I made the same mistake the dvd needs the blue/red glasses and you need the bluray as i did.
