Toshiba 37wlt66 screw up! - help needed
Discussion in 'Home Cinema Buying & Building' started by kcscga1, Feb 9, 2009.
  1. kcscga1
    kcscga1
    May 2, 2006
    3
    I have a tosh 37wlt66 that must be about 3 years old and it has just been replaced by a new samsung.
    The tosh was on the wall doing a sterling job and I kept the stand for this exact situation - where it gets demoted to the 'back room telly' - however I am the kind of person who knows the value of keeping all the stuff I remove, but this time there has been a gremlin in my otherwise foolproof selotape to the stand approach for the screws/allans.
    Hopefully I am not the only person to have been so dumb as to lose the screws/allans for this kind of TV....
    So.... could someone tell me the specification of the 5 screws/allans/bolts that are used to secure the TV to the stand??? - I would really appreciate it
    I have tried to see if the service manual has the spec, but with no luck on finding it.
    Thanks for reading at least.....
    Glenn
    :lease:
