Toshiba 37WLT58 - BOX SIZE ??
J
jerkyboy
Can someone please give me the box dimensions for the Toshiba 37WLT58.
I am picking mine up on Saturday and I need to know if it will fit in my car.
richard plumb
TV box is 90w x 38d x 72h
If TV&VideoDirect are correct, this component weighs 22Kg.
The Stand box is 94w x 12d x 47h
This weighs 39Kg.
J
jerkyboy
Richard, many thanks but are you sure these are the 37" dimensions ?.
According to the manual that I downloaded the 37" is 92cm wide !.
po_man
I think that TV&VideoDirect must have the wrong info because the width of the panel alone for the 37WLT58 (according to my Toshiba brochure) is 915mm.
Box dimensions for 37WLT58 -
w:1023 x h:800 x d:380 (mm)
