Toshiba 37WL56, tosh are sending out the repairman!
Discussion in 'LCD & LED LCD TVs Forum' started by Rob Sheep, Jun 5, 2005.
  1. Rob Sheep
    Rob Sheep
    Aug 17, 2003
    Well, after a week discussing the problems I've been having with my new 37WL56, what started out as a mains buzz which was then diagnosed as backlight noise is finally going to be sorted out.
    I called Tosh tech support on Friday (third time in a week) to see if I was going to be given a different answer to the problem, after living with a dark picture for days with the backlight down and my wife on my back for buying a TV that is too dark with a buzz, I thought it was time to get a straight answer.
    So this time I've been told that the backlight should not make a noise, there should also be no noise when the backlight is turned up! After explaining the other problem I have with it not recognizing film formats correctly, the guy at Tosh admitted that there is a problem with the set and it needs to be looked at ASAP, so sometime this week a repairman from Toshiba is coming out to see what can be done. :lesson:
