Toshiba 3738db Sound Problems
Discussion in 'General TV Discussions Forum' started by BOBSTEEL, Dec 29, 2006.
  1. BOBSTEEL
    BOBSTEEL
    I have started to suffer from lack of sound from this very reliable tv. On turning on, there is no sound, yet after waitinf to warm up for 10 mins, a very light touch on some part of the cabinet sometimes works and the sound returns, never ofcourse the same spot.
    Not being a techy person, does this indicate some kind of sound card on the way out!
    Its a bit large to put in the car, so any help before calling out someone would be great!
  2. JayCee
    JayCee
    Jan 20, 2004
    23,632
    Lanarkshire
    +2,551
    It is probably a "dry" solder joint especially if mechanical vibration (tapping the set) restores the sound.
    I would advise against having a go yourself unless you are competent with a soldering iron and are comfortable handling electronic components...as well as the safety issues.
    It is worthwhile calling in an experienced TV engineer for an estimate.
  3. BOBSTEEL
    BOBSTEEL
    Much Appreciated! Will Heed Your Advice.
