toshiba 37-wl66 hdmi connection toshiba 360e
B
barns78
i have just bought a toshiba 360e to go with my toshiba wl66 after fitting the hdmi cable i cannot get the picture on my television any advice for the old fellah:confused:
Bolander
It's a while since I had a 360E, but if I remember correctly HDMI is not switched on by default. You have to connect the player to the display with a scart cable, then find the menu item which allows you to switch on HDMI. You can then disconnect the scart cable, connect the HDMI cable, and you should see a picture on the display.
