Toshiba 36ZP48P - RGB Problems
Discussion in 'Televisions' started by philbert, Jun 19, 2005.
  1. philbert
    philbert
    Jun 13, 2003
    2
    Hi all
    I have just purchased the Toshiba 36ZP48P 36" TV and have hooked up a Sky+ unit to the Ext-1 input. According to sall the blurb, the ext-1 and ext-2 inputs are RGB compatible although the picture from the Sky+ box looks 'harsh' i.ae. like the input is component. Does anyone know if the inputs are RGB only, switchable RGB / Component or auto sensing?
    Be grateful of any comments.
    Phil
  2. pixelpidgeon
    pixelpidgeon
    May 5, 2005
    3,238
    +628
    :) Hi Phil.
    Cant help you with your question. But i am inteareste din an answer & any feedback you have so far on your new tv. I am looking into buying this tv myself... as im not quite ready for the plasma jub just yet,. and the price of this tv at the moment looks a bargain!
    cheers, Gra
  3. fdxd
    fdxd
    You have to change SKY settings to RGB. Then your picture will be clean.
    As for the set its nice provided you dont use 60Hz material.
