Toshiba 36zp48p and 480p
Discussion in 'General TV Discussions Forum' started by beasty54, Sep 12, 2005.
  1. beasty54
    beasty54
    Mar 16, 2005
    6,102
    Lincoln
    +509
    I have the Toshiba 36ZP48P and a modded UK xbox.
    I'm thinking of buying the Official microsoft High Definition pack from the US but i'm just wondering if i'm gonna see a lot of difference when playing imported US games that run at 480p
    Sorry if this is a stupid question but i have no experience with high definition whatsoever
    thx in advance
    michael
  2. 88mphster
    88mphster
    Sep 3, 2005
    5
    3
    I'm in the same position as you.
    Also anyone know whether the xbox media center is able to run at 480p?
  3. TankTopLover
    TankTopLover
    Aug 28, 2005
    4,146
    +189
    I think pal games run at 480p aswell?? I hope so because i just ordered a high def cable (i have the 32" ZP48)
    I have a modded xbox and used the region switcher to turn it to NTSC,but i was hoping PAL games would run at 480p?? :confused:
    EDIT:
    Just researched and yes you can run in 480p as long as you have a modded xbox and have an application called 'Enighma Video Switcher'.This flashes the eprom and switches from pal to ntsc .. enabling 480p support.
    95% of PAL/NTSC games support 480p..some even support 720p (like Amped 2)
    Halo/2 support 480p.
    If you have Auto Installer Deluxe,then enighm,a comes preloaded with it,all you do is select it from the app launch menu.Thats what i did :D
  4. beasty54
    beasty54
    Mar 16, 2005
    6,102
    Lincoln
    +509
    Seems your right about PAL games supporting HD...well most of them have the code left in from the NTSC version anyway.
  5. 88mphster
    88mphster
    Sep 3, 2005
    5
    3
    stuart69, where did you order your cable from?
  6. Raze
    Raze
    Dec 21, 2003
    875
    UK
    +13
    Can you let us know how you get on please?
    I thought the 36zp couldn't handle Hi-Def signals?? :-/
  7. cooleo_no1
    cooleo_no1
    Jul 14, 2005
    116
    19
    480p technically isn't Hi-Def.
    Its progressive - which means more frames per second and better quality to the eye. I think it's called EDTV.
    Please correct me if I'm wrong, I'm only a newbie :D.
  8. Raze
    Raze
    Dec 21, 2003
    875
    UK
    +13
    Ah right sorry I was thinking about the Xboxs 1080i modes for a minute ;-/
  9. jwramsay
    jwramsay
    Sep 7, 2004
    1,629
    West of Scotland
    +72
    If you want an XBOX to Component cable for 10 quid delivered PM me.
