Toshiba 36ZP48 - Set up advice please?
Discussion in 'TVs' started by The Prodigal, May 29, 2005.
  1. The Prodigal
    The Prodigal
    Hi all,
    New member and complete amateur here, so please be gentle...... :lease:
    I've recently bought a Toshiba 36ZP48 and would like advice on leads/cables and how best to connect up my kit for optimum viewing pleasure?
    I'll be connecting a Sky Digital box, Panasonic DMR-ES10 DVD Recorder and PS2. I'll be using the DVD Recorder mostly for recording off Sky and playback of such recordings and other DVDs.
    Any help/advice gratefully received! :thumbsup:
    Thanks,
  2. Spok
    Spok
    Nov 25, 2003
    96
    London, England.
    Use high quality scarts and components leads. I use Ixos and they certainly do make a big difference.
    If you can use the component in on the TV, you will get amazing results, especially if you feed it progressive scan.
    Spok.
  3. The Prodigal
    The Prodigal
    Thanks for the info Spok.
    Anyone any suggestions how best to connect up the scart and component leads for the best results?
    I'll be hooking up to my Toshiba 36ZP48 the following equipment:-
    Sky Digital box
    PS2
    Thanks,
