Toshiba 36zp48 screen problem
Discussion in 'General TV Discussions Forum' started by slybri, May 24, 2005.
  1. slybri
    slybri
    Jan 7, 2005
    15
    Sunderland
    Hello all I hope you can help me I had my toshiba for a couple of month now and I am very happy with it but recently ive notice a red stain appearing in the top left hand corner of the screen, this is only noticable on white backgrounds, I have since moved my external speaker to see if it the cause of the problem but I would have expected the speakers to be shielded.Has anyone else had this problem? I still think it has the best pq of any tv ive seen so any suggestions would be appreciated. :lease:
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Slybri,
    As you've realised, what you describe is a classic impurity problem caused by a stray magnetic field. :mad:
    It's probably the loudspeaker, but are there any other large metal objects (radiator, perhaps) nearby?
    Having removed the source, you now have to de-gauss the tube. :lesson:
    This should happen when you switch on from cold, although it may take several goes.
    Alternatively, use of a de-gaussing tool may be necessary.
    (Some people use a hair-dryer! :eek:
    Can't comment on this method,
    as TG has no use for one. :rotfl: )
    Good luck. :smashin:
  3. slybri
    slybri
    Jan 7, 2005
    15
    Sunderland
    The only speakers next to the tv are the ones supplied by the manufacturer,do you think I will be able to claim on the warranty if this problem doesnt go away?
  4. Spok
    Spok
    Nov 25, 2003
    96
    London, England.
    Get it looked at or changed under warranty, especially as it is only a month old.
    Spok.
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,832
    Galactica C.I.C.
    +272
    As tight git has said, it looks like the screen needs to degauss its self.
    When the tv comes on from cold you should hear a low bassy ping type sound. This is the sound of the tvs own degasser. If it is not working, unplug the tv and then try again after a couple of hours. It may take 3 or 4 attempts to sort it out though.
    Alternatively if this fails, contact the place of purchase and get them to have a look under the warranty.
  6. slybri
    slybri
    Jan 7, 2005
    15
    Sunderland
    Thanks for the advice guys ive moved the speaker but still the problem exists the next step is contact the place of purchase I will let you know the outcome.
  7. slybri
    slybri
    Jan 7, 2005
    15
    Sunderland
    Ive had the engineers out and they tried degausing the screen with no effect the told me they need to replace the tube.Should I let them replace the tube or insist they replace the tv?
  8. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, if they couldn't get rid of it by using an external degaussing tool then the 'basic' purity adjustments of the crt need to be re-adjusted - it doesn't need a new crt. A simple job (in fact best carried out in situ). Obviously, not a DIY job but since its under guarantee 'go with the flow' and let them change the crt. If you're subsequently not happy insist they replace the telly. (I'm sceptical that they'll change the crt even if they say they will/have) regards, yt.
  9. DRGL
    DRGL
    Mar 30, 2004
    751
    Shropshire,UK
    hmmm,i would demand a new TV-if you accept the repair you then limit your power of rejecting the goods if it all goes pear shaped. There really is no reason for a new tube as has already been stated,this would make me very wary of their repair skills!!
  10. slybri
    slybri
    Jan 7, 2005
    15
    Sunderland
    A company called DBS service center came out to look at the tv my daughter was in at the time and she had to loan the guys a phillips screw driver to get the back off the tv (doesnt boost my confidence) also had to loan them a torch to get the serial number,I spoke to them today and they tell me that they have informed Empire direct that the tube needs replacing and they are waiting for a reply to see if they replace the tube or the TV, I hope its the TV as I dont have much faith in the engineers,I will let you all know what happens, thanks for the comments.
