Toshiba 36zp48 Release Date??
Discussion in 'General TV Discussions Forum' started by Dessie, Jun 25, 2004.
  1. Dessie
    Dessie
    Apr 10, 2004
    13
    3
    I am looking to replace my ageing television, I had narrowed my search down to the Philips 9618 and the Philips 9509 (both 32inch) I would have really liked to go up to the 9618 36inch but the cabinet is just to large to fit where our tv sits.
    On looking at the Toshiba 36zp38 the cabinet will fit so I could go for the 36 inch, I know this model is now being replaced by the 36zp48 does anyone have any idea when it is due on the market and if any of the faults from the previous model have been addressed.
    Any comments would be gratefully received.
    Dessie.
  2. transwest
    transwest
    Nov 8, 2003
    349
    Cornwall
    +7
    according to Toshiba - June 2004 ! I think it's closer to July. It looks though, that the only changes are: Silver Frame surround (instead of Black) & a slight change to the cabinet/stand. Toshiba told me that the ZP48 now has Active Vision !!!! but so does the '38.
    If anyone knows more, I'd be pleased to hear also & I'm still struggling to get a proper Price Match
  3. RaynerN
    RaynerN
    SCREEN
    Visible 86cm face flat 16:9 screen
    Invar mask
    Active vision-:
    -High definition pixel process
    -Advanced 100Hz
    -Progressive scan
    Digital comb filter
    Super scene control
    Super real transient
    Colour detail enchancer
    Dynamic scan control
    Digital noise reduction
    Colour acutance improver
    Sound
    Dolby Digital 5.1
    68w RMS audio output
    Built in sub woofer
    Tuning
    UHF/VHF/Hyper
    PAL I/BG/DK
    SECAM BG/DK/L
    NTSC BG 4.43
    Geomagnetic adjustment
    Connections
    Input:
    3 scart (2 full RGB input)
    AV input
    Component video input
    Audio input
    S-Video input
    Output:
    Digital audio output
    Headphone socket
    Audio output
    Ease of Use
    Auto set-up
    128 pages fastext
    Teletext sub page control
    Icon OSD
    Widescreen signalling (WSS)
    Manual select screen size mode
    Panel lock
    On/Off timer
    No signal off
    Blue back control
    Quickview (channel return)
  4. artgar
    artgar
  5. bumble
    bumble
    will the zp48 support true PAL progressive scan???
    can't find a confirmed spec........
