TOSHIBA 36ZP48 Problem
Discussion in 'General TV Discussions Forum' started by gware, May 2, 2005.
  1. gware
    gware
    Hi I've just got a new TV, the Toshiba 36ZP48 and it seems to have a problem. In the top left hand corner the colours are darker than the rest of the screen, how I just want to know if this is something you can fix or whether i should have it sent back for a replacement. Thanks
  2. TheBaron
    TheBaron
    Dec 28, 2004
    +8
    I don't think you can fix it, I have seen several post from people with 'patchy' screens on this tv. Luckily mine was perfect :thumbsup:
    You could try degaussing it (switch on and off a few times) , but really, an engineer needs to visit, most likely neds changing. :suicide:
    Where did you buy it from ?
  3. slybri
    slybri
    Jan 7, 2005
    15
    Sunderland
    I have a problem with red stain in the top left hand corner of the screen which is next to where the speaker stands,could anyone tell me if they have had the same problem,Iwould have thought the speakers were sheilded?
