Toshiba 36zp38b and hi def- xbox
Discussion in 'Xbox Forums' started by Klang J, Nov 22, 2004.
  1. Klang J
    Klang J
    Nov 21, 2004
    7
    hi
    i have ordered a hi def pack for my xbox so i can connect it through component cables for a beeter picture. Now i am aware that hi def are usualy for plasms projectors etc but can my tv support hi def ? am sure i have read it some where? Just to mention i already have a third party component cable installed will i notice any difference?
  2. sjgill
    sjgill
    Dec 11, 2002
    498
    Coventry
    I have this set myself and if you have a "special" xbox you can change the output to 480p which is suported.
    And yes you will definatley see the difference...
