Toshiba 36zp38 remote shortcut
Tony 21
Hi all,
Does anyone know of a shortcut on this remote that can make the tv go to Ext 4 when swiching on instead of having to scroll through the buttons?
Thanks.
allengn
Basically No, And I agree it is a pain:thumbsdow
However the quality of the set more than makes up for this inconvenience.
TheBaron
Tony 21 said:
Hi all,
Thanks.
It is a bit of a pain, my previous TV (15 yo panasonic) would automatically switch to AV input when DVD player was switched on. :cool:
allengn
Which will still happen if your DVD is connected via SCART. (Because SCART has a signal cable included).
Using Component video input, which is what goes into EXT4, no signal is sent, and hence you have to manually select the correct channel.
red16v
Does this telly have 3 scart inputs ? if so would the following be easier ? Connect scart out of DVD to scart 3 on the tv. If my plan works (and it might not !) switch on the dvd and the tv should 'go' to external 3 - then press 'external select' on the tv remote and it should go to the 'next one up' ie, ext 4. Pretty sure this would work on my ZP48 and may work on your ZP38 if it is similar. Not quite what you wanted but reduces the 'problem' to simply switching the dvd on using the remote control and then one press on the remote control ? as i say, might not work but worth a try if you have a spare scart lead (with wiring for remote signaling). Regards, yt.
Similar threads
Podcast: LCD TVs for Movies, Physical Discs?, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
