H
Homer Simpson
Have the above TV & Toshiba SD330e multi-region DVD. 3 questions i'd like some guidance on pls.
1. Screen Geometry is ever so slightly out - top right corner bends slightly upwards. Only really noticable when Sky EPG is on, never noticed it when watching a programme. Is it worth an engineer visit or sending it back? or am i likely to end up in a never ending cycle of return visits etc...
2. Anyone advise optimum settings for contrast / brightness / colour etc... of the 3 pre-defined settings picture mode 1&2 are awful, 3 isn't so bad but a little dark so i need the manual settings i think
3. DVD player outputs DTS & DD5.1 but TV only decodes DD5.1 - what can i add to the system to decode DTS & ideally still only use 1 set of speakers for DVD/TV/Sky broadcasts
Many thanks in advance.
