Toshiba 36ZP18P - Good or Bad???
Discussion in 'TVs' started by Jimbob, Feb 4, 2002.
  1. Jimbob
    Jimbob
    Hi all
    I have decided against buying a Sony TV. The choice and troubles people are having have finally put me off.
    Doing some more research I found the Toshiba 36ZP18P and was most impressed by the small frame.
    If anyone has one of thse could they let me know if its any good. Does it suffer from any problems and most important where did you get it from and how much.
    Im looking for the best price from a company known to be reputable for example I found this company here : http://www.avshopdirect.co.uk/shop1/wide/tosh_36zp18p.htm and for the price I would love to know if this shop is any good or not before I decide.
    Can anyone help?
    Jimbob
  2. Doubledoom
    Doubledoom
    I suggest you read the existing threads rather than create a brand new one that duplicates what has already been said.
  3. Markster
    Markster
    Jimbob as Doubledoom suggests have look around on this forum for the large toshiba 36zp18 thread.
    To answer your other question the cheapest place to buy this set is i believe still qed-uk.com
    HTH
  4. Jimbob
    Jimbob
    After spending an hour doing just that it would be nice if someone could sumarise.
    I read about these lines at either side but also see some disapear over time. Any insight or experience with this now time has passed since the first posts?
    Plus good places to get one I could use some help with.
    Jimbob
  5. Jimbob
    Jimbob
    Cheers markster. Looking now
    Jimbob
  6. HBK757
    HBK757
    Jan 15, 2002
    153
    16
    Jimbob - can't comment on the TV but do not use www.avshopdirect.co.uk or www.robertwhyteltd.co.uk (same company), trust me you'll be taking your life in your own hands :D
  7. Doubledoom
    Doubledoom
    You can't miss the main thread. It must be the longest thread on this forum and has had posts made to it in the last 24 hours.
    I have just checked the televisions forum, rather than the view new posts which i normally use, and i see the Toshiba thread right at the top.
    New optician needed? ;)
