Toshiba 36ZP18
Discussion in 'General TV Discussions Forum' started by Silent Fly, Mar 10, 2003.
  1. Silent Fly
    Silent Fly
    I checked everywhere but I can't find it... :confused:
    Do you know the space between shelves in the Toshiba 36ZP18?
    Thanks for your help!:smashin:
  2. cully
    cully
    Feb 7, 2003
    3
    hope this helps.
    a=132mm
    b=124mm
    c=115mm
    d=414mm
  3. oggy
    oggy
    Feb 5, 2002
    236
    Turriff
    +6
    By the way u can take the shelves oot.:smashin:
  4. Silent Fly
    Silent Fly
    Thanks a lot!:smashin:
    That is exactly what I needed!:clap:
  5. Silent Fly
    Silent Fly
    As I suspected... my Marantz 5300 (164mm) would not fit in any shelf!:thumbsdow
    ... and if I take one shelf out there is not going to be enough space for my DVD (Toshiba 220) and my VCR! :suicide:
  6. topmba
    topmba
    Feb 13, 2003
    250
    Bedfordshire
    +4
    What about fitting the DVD and VCR side by side on one shelf?
    The ZD model has only two shelf and seems to stand taller than the ZP.
    Do you need an open cabinet?
  7. Silent Fly
    Silent Fly
    That was my original idea... but I think the shelf is too small to do that.
    Do do not really need an open cabinet but the original one supplied with the TV looks quite nice!:cool:
