Toshiba 36ZP18. What wall mounts do I need for speakers??
Discussion in 'General TV Discussions Forum' started by Jimbob, Feb 14, 2002.
  1. Jimbob
    Jimbob
    Hi all
    If you own one of these TV's could you let me know if the package includes the wall mounts. I assume they dont.
    If not could you let me know where I can get some matching ones - preferably off the net.
    Thanks in advance!
    Jimbob
  2. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Jimbob,
    The speakers have small platsic attachements screwed to the back, which have a slot in them to allow you to hang them from a screw on the wall. It's one of those kind of inverted T slots where you put the fitting over the screw and slide it down. I don't think there's any way that you can adjust the rotation or tilt though.
    I can't vouch for how effective the wall mounting is though, because I've got mine on stands.
    Nigel.
  3. Jimbob
    Jimbob
    Yeah I know the type of thing. But as you say they dont let you angle them at all :/
    Jimbob
  4. Markster
    Markster
    FWIW. I decided to upgrade my Toshiba 36ZP speakers to some seperate mission speakers, the difference was huge!!
  5. 306GTI6
    306GTI6
    What Mission speakers did you get?
    I might upgrade mine if the difference is worth it.
    Andy.:)
  6. Markster
    Markster
    I went for the new Mission M Series. M73, M7DS, MC1. and bought a Yamaha Amp and then bought a seperate subwoofer.
    Most definately worth every penny.
    I have to admit to being a little bit worried at the time of ordering them, I wasn't sure how much difference separates would sound and whether the investment would really be worth it.
    But the difference between the missions and the tosh speakers wasn't even really describable
