Toshiba 36ZD26
Discussion in 'TVs' started by o0OBoBO0o, May 27, 2003.
  1. o0OBoBO0o
    o0OBoBO0o
    Jul 25, 2002
    185
    +9
    I hope someone can help, I've had a search and cant find the answer I'm after. Here goes.
    Am I correct in the assumption that AV2 can output whatever is being fed in via AV1 ?
    The reason I ask is that I want to be able to run a flat panel telly in another room via the easiest method. It struck me that this would be the simplest, all I have to do is run a 6ft Scart to the other telly.
    Am I right in this assumption ? I f I am how do I configure the Telly ?
    Many Thanks
    BoBBoB
