SuperSeven
Established Member
- Joined
- Oct 29, 2005
- Messages
- 576
- Reaction score
- 30
- Points
- 73
I know a few people have brought or are thinking about buying the Toshiba 350e upscaling DVD player, but may have been put off by the very bright blue light on the front on the dvd tray.
It can be turned off in the setup menu, however this has to be re-done every time the player is switched on again (Not a fault as this is confirmed in the manual)
I have the perfect solution which does break anything or invalidate the warranty.
If you look closely you'll see the blue strip isn't actually a long series of LEDs. It's simply a strip of clear plastic set into the front of the opening dvd tray. Then when the dvd tray is closed this strip is lit up by 2 blue LEDs mounted either side of the dvd tray.
The simple solution is to open the dvd tray, then stick on 2 small pieces of black electricians tape onto either end of the transparent plastic strip on the dvd tray. Then when the dvd tray is closed this stops any of the blue led light entering the dvd tray strip. It's a very effective solution and turns an incredibly bright blue 5 inch strip into 2 small blue dots.
