Toshiba 350
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by TimF, Jul 25, 2005.
  1. TimF
    TimF
    Just got one of these - superb.
    The Tosh 340 multiregion hack works.
    i.e.
    1 Open Tray
    2 Key "2403960"
    3 key "enter" repeatedly to go to region "9"
    4 close tray
    Cheers and all the best
    Tim
  2. Craigy
    Craigy
    Jul 25, 2005
    4,949
    +825
    Just would also like to confirm this works for the 350 - Just tried it now, only got the player 5 mins ago!!
  3. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,068
    Essex
    +73
    brilliant thanks for that TimF
    one thing to add you must set the dvd player in the dvd player's menu to auto in the picture settings under pal or ntsc
    otherwise you get a fast motion image which was really weird.
    thanks again!
    really happy with my sd350e and its just got even better!
    :thumbsup:
  4. GFROSTY
    GFROSTY
    Sep 4, 2005
    58
    TimF
    You are a star, just got one of the 350e's, awesome little player!
    It would play some region 1 dvd's but not shrek, until now!
    Thanks!
  5. yarand
    yarand
    Aug 22, 2004
    101
    London
    You and the other guys really seem to rave about the Toshiba 350e - are you using it with HDMI or Component Video connection? Is the HDMI output significantly different to/better than Component Video output?
  6. Sheltie
    Sheltie
    Nov 22, 2004
    56
    9
    And what digital cables are you using, are ther any in the box?
  7. Craigy
    Craigy
    Jul 25, 2005
    4,949
    +825
    Its just a composite lead out of the box, I bought an hdmi lead for 30 quid, have not got a component cable so cant compare the two, I am impressed though with the clarity and the colours, a good test is monsters inc, that looked alot sharper than what I remember on my old player.
