Toshiba 3377DB Spares or advice req please
Discussion in 'Televisions' started by Chipster, Dec 15, 2003.
  1. Chipster
    Chipster
    Nov 12, 2003
    203
    UK
    Hi forum.
    I have an old (5-6 years) Toshiba 3377DB 33in 4:3 TV. It has developed a couple of faults. First the picture would go unless the scart plug/ socket was jiggled. Then finally the TV went dead with only the green standy LED flashing.
    I suspect initial dry joints, and now possible component failure as a result. The tube is good and the picture was fantastic, so I would prefer to repair rather than bin it.
    So rather than lugging this heavy TV around to repair shops, I am looking for a source of supply for the circuit boards in the hope that a swap will cure the problem.
    Any advice on a cure would be appreciated.
    Many thanks.
    Chipster.
