toshiba 3327db
Discussion in 'TVs' started by anock14258, Jan 4, 2005.
  1. anock14258
    anock14258
    have a toshiba 3327db television
    i can enter service mode by pressing the f and a/v button and keying in 1048
    to give the M in top right corner then use the picture/sound button to select option to change then using audio up down to change the settings.
    after playing around with the settings to correct a pincusion effect which i corrected i found for some reason i cannot now bring up the teletext which was working fine before i entered service mode.
    i think i may have inadvertantly altered something in service mode whilst poking around.
    anyone any ideas what i could have done wrong.?
    or anyway to do a factory reset on this model.?
