Toshiba 330e
Discussion in 'Blu-ray & DVD Players & Recorders' started by mattrixdesign, Jan 8, 2005.
  1. mattrixdesign
    mattrixdesign
    Any one know what DVD-R media will work in my Tosh 330e DVD player? I made a home movie and put it on a Maxell DVD-R - the Tosh wont read it, but my PS2, PC and cheap JVC DVD player all play it fine!!!
  2. phunt
    phunt
    May 8, 2003
    423
    +5
    Well i cant recall mine ever refusing to read anything but the main discs i used it it were datawrite orange ritek G04.
  3. mattrixdesign
    mattrixdesign
    I tried another brand of DVD-R last night, the DVD worked on my JVC DVD, PS2 and PC, but again not on my Toshiba :suicide:
    I think I will contact them to see what they recommend.
  4. burnmypies
    burnmypies
    Verbatim work fine for me
  5. shodan
    shodan
    Dec 11, 2001
    11,552
    shoeburyness
    +6,448
    Did you ever have any luck with this? I face exactly the same problem...
  6. mattrixdesign
    mattrixdesign
    Yes! None of the unbranded and cheap ones I tried worked - however Phillips +R work fine on the Tosh! :clap:
  7. shodan
    shodan
    Dec 11, 2001
    11,552
    shoeburyness
    +6,448
    That'll teach me to buy cheapo dvd-r's!!! But surely if Toshiba say it will play DVD-R's and it doesn't, then its not doing what it is advertised as being able to do?
  8. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    I tested my 330 and it played unbranded disks from Novatech and Dabs without failure.
  9. shodan
    shodan
    Dec 11, 2001
    11,552
    shoeburyness
    +6,448
    These machines seem very hit and miss! I'm considering going down to RS (can't believe I'm considering it!!!) and buying a Pioneer 575. Although it'll be cheaper for me to buy new and more expensive dvd'rs' than the one's I bought...
  10. shodan
    shodan
    Dec 11, 2001
    11,552
    shoeburyness
    +6,448
    I've fixed the problem I was having! I went out and bought a Pioneer 575!!! So far this has proved to be automatically multi region but it has played all my DVD-r's perfectly, it has the newest firmware (So it loads quicker and some other stuff) but the actual A/V quality is a vast improvement over the Tosh SD330e, which was by no means a poor quality player!
    In fact I think I'm going to have to re callibrate the system as it is now completely different!
    Well worth £99 and the only regret I have is that I didn't buy one before!!!
