Toshiba 32ZT29B On-Screen Guide
Discussion in 'Televisions' started by Stompa, May 17, 2004.
  1. Stompa
    Stompa
    Feb 9, 2004
    74
    +7
    I'm having some problems with the On-Screen Guide and On-Screen Info on my Toshiba 32ZT29B. The display for a few of the channels appears to be 'stuck'. For example Channel 4 has said "Hollyoaks" for several days now. Most of the channels though are fine.
    Is this likely to be a problem with the TV itself, or with badly transmitted data?
    I suspect the latter, but would be grateful for a second opinion.
    Stompa
