Toshiba 32ZP48 vs 32ZP46
Discussion in 'TVs' started by DPLeeds, Dec 28, 2004.
  1. DPLeeds
    DPLeeds
    Read a lot about the 32ZP48 but I don't really want external speakers due to the small room I've got - the set will only just fit in the corner as it is!
    Was just wondering whether I would therefore be better with the 46 if the only difference in the models is the sound system? I am right??
  2. MixerMan1
    MixerMan1
    Oct 15, 2004
    16
    Redcar
    Yes the only difference is the speakers + the inbuilt 5.1 surround sound out put on the 48 model
    The 48 comes with 4 external speakers + the standard speakers on the TV
    The 46 comes with the standard speakers on the TV
    I have the 48 and only use the standard TV speakers - they are good enough IMHO
