Toshiba 32zp48 set up query
Discussion in 'General TV Discussions Forum' started by silverknapper, Jan 10, 2005.
  1. silverknapper
    silverknapper
    Dec 26, 2004
    10
    Hi all
    Just a query on the dolby digital set up. When playing a DD DVD, when I press the audio set up button there is no menu there for Dolby Digital, only for pro logig and hall, theatre etc.
    Is this because I don't have a coaxial or optical cable between the DVD and TV? If I get those cables will the menu appear?
    Thanks for your help
  2. Sly Fly
    Sly Fly
    Nov 23, 2004
    1,989
    116
    +718
    Yup. Or at least it should do. Dobly Digital, as the name implies, will have to rely on a 'digital' cable connecting the two. I'm guessing you were using the red/white phone cables, which will only give you Pro Logic II
  3. shymonk
    shymonk
    yep digital only available from digital source: ie optical/coaxial
