Toshiba 32ZP48 Flash/Buzz!!!!!!
R
robjohnw
Hi All, I bought a 32ZP48 from Direct Digital last November and I must say it's great, picture and sound all brill BUT resently the screen has started to flash and the speakers buzz. It only lasts a split second and only happens once or twice an hour after the TV has been on a couple of hours but it's getting me worried. I've spoke to DD and they said my TV is 'out of sync' with my satilite, DVD and vidio connected to it, I should disconnect them retune the TV and reconnect. Sounds abit iffy to me!! Any ideas anybody?
TheBaron
Sounds a bit like interference from a thermostat turning on/off central heating ?
R
robjohnw
Thanks for that, sets my mind at ease a little. I'll keep note to see if it gets any worse.
spocktra
Get an engineer out asap.Possible fault in the text module.Or somebody competent to remove the module to see if it cures.The set will operate without it.
R
robjohnw
Thanks for that. I've heard this about the text module before. What is a text module?
R
robjohnw
I've emailed Digital Direct to ask for their comments regarding the text module. Awaiting reply. Will keep y'all informed.
R
robjohnw
Engineer came out last Friday (25th Feb) Re soldered a couple of dry joints and replaced the text module. Watching TV Friday night and exactly the same thing happened!!!! Called Digital Direct today, they're arranging for engineer to come out again!!! What fun!!!!! NOT!!!!!!!
spocktra
Toshiba assured me the problem was with a batch of faulty text modules,i hope your replacement isnt the same batch.
R
robjohnw
Don't know but the engineer is coming again on Friday so I'll put it to them!!
